Different configuration for TV and DVD?
Discussion in 'Plasma TVs' started by Norbert666, Oct 12, 2005.
  1. Norbert666
    Norbert666
    Dec 15, 2004
    168
    +4
    Do people have different settings for watching TV and DVD? Or do you use the same for all?
    I have read about various settings for my Pioneer 506XDE.
    In the screen's settings, I can select STANDARD, DYNAMIC, MOVIE & USER.
    Clearly USER is where I make my own config.
    Any advice/help would be much appreciated.
    James
  2. rtoonen
    rtoonen
    Jan 14, 2003
    16
    Yes , I use different settings for TV (standard) en DVD (cinema). You can change these setting, but not the Dynamic-set.
  3. Mep
    Mep
    Dec 25, 2004
    9,552
    +472
    your sources will always output different levels of colour, contrast, brightness etc so you would normally expect to have different screen configs for each.
  4. Blue Triangles
    Blue Triangles
    Sep 19, 2005
    992
    +79
    On the 506XDE, can you save different settings for all the different inputs?
  5. Norbert666
    Norbert666
    Dec 15, 2004
    168
    +4
    I'nm sure it wouldn't let me change the standard when I tried? Maybe I was just being thick.
    Would you be so kind as to give me some suggestions on settings as a starting point?
    James
  6. rtoonen
    rtoonen
    Jan 14, 2003
    16
    My movie-settings:
    contrast 25
    brightness 1
    colour -2
    tint 2
    sharpness 7
    purecinema off
    drive mode 100 hz
