Different audio outputs from one receiver?
Discussion in 'AV Receivers & Amplifiers' started by tefkay, May 18, 2004.
  1. tefkay
    tefkay
    I have a fairly large room. I want to setup a home theatre system and then also put ceiling speakers in different parts of the room (dance floor, bar, etc - 8 in total). Is it possible to have one audio source going to the theatre speakers and another audio source to the 8 "rear" speakers? Can I also control the volume separately for each speaker (or group of speakers)? I would like to do this with one amp. What kind of amp do I need for this?
    TIA
  2. tefkay
    tefkay
    Let me clarify that I would want to play the sound in both areas at the same time. Is this the multi-room capability?
