differenece between panny th37pe50 and th37pwd7??
Discussion in 'Plasma TVs' started by 4bp, Aug 23, 2005.
  1. 4bp
    4bp
    Aug 19, 2005
    71
    hi
    can anyone please tell me the differnce between the panny th37pe50 and th37pwd7??
    i am looking to buy my first plasma and panny seem to be the favourite on this forum. i am not sure whether to get an hdtv one or not (if i do i will prob go for the 37pv500) but was wondering what the above 2 plasmas are like.
    thanks for the help!!
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,767
    Norwich
    +646
    There is loads of discussion regarding the differences between the panels and the TVs.
    The TV units are excellent as you get a tuner and speakers built in, if you want the best picture and are likely to add a scaler at a later date then the panels will be a better choice.
    Have a good read through the Panasonic threads as this seems to crop up in everyone of them.
