DIfferenece 3 RCA Component vs 5 RCA
Discussion in 'Cables & Switches' started by dgharwood, Aug 3, 2004.
  1. dgharwood
    dgharwood
    Apr 1, 2004
    88
    Swansea
    +6
    I currently am using a ShowCenter and DVD Player Component out to my Denon Amp and outputting that to my Panasonic Th42PW6.
    I am soon to introduce a XBOX Component into this equation and do not have enough inputs on the Denon, so am going to buy a switch box.
    The question I have is that whilst the ShowCenter and DVD Player and Denon only have Component R, G and B, the XBOX high def kit has the 5 which I believe are the R, G and B along with horizontal and vertical sync.
    Do I need to use the H and V sync on the XBOX high def or will I get away with using just the R, G and B.
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Note that RGB(HV) is not compatible to 'Component' aka YUV/YPrPc/YCrCb, even though the colors of the 'Component' connectors imply otherwise!
    Technically RGB and YUV are both component signals, but often the term 'component' refers to YUV only. :lesson:
  3. Damnyoureyes
    Damnyoureyes
    Jun 17, 2004
    46
    There's only 3 RCAs for the video the other two RCAs on the xbox kit are the sound left and right
  4. dgharwood
    dgharwood
    Apr 1, 2004
    88
    Swansea
    +6
    Excellent - thanks very much.
  5. Damnyoureyes
    Damnyoureyes
    Jun 17, 2004
    46
    Also the component signals are Y Pr and Pb which will be fine
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,410
    The Borders
    +3,228
    dgharwood
    It gets mighty confusing when the hardware manufacturers choose to use Red, Green and Blue Phono sockets for YPbPr Component video signals!
    Best regards
    Joe
    PS We have the ideal switcher for you - and even if you did have to mix RGBHV with YPbPr we can do that too!
