Differences between SVS Ultra and Plus drivers
Discussion in 'Subwoofers' started by Ian J, Sep 28, 2004.
  1. Ian J
    Ian J
    Aug 6, 2001
    25,630
    +4,906
    I came across a post by Tom V in a forum over the pond and I thought I would copy and paste it here as it is an interesting explanation of the differences between the two drivers and confirms my own thoughts that there are very few differences at normal listening levels but the differences show when you start to push them.
  2. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,098
    notts.
    +71
    Hi Ian
    Tom did reply to my email a while back when i asked him if it would be worth upgrading to the pcu from my pc+ and he said it wouldnt really as i wouldnt notice any audible difference unless playing at very high volume in a large room,Still i do dream of the day i can have a plasma which will then leave me room for a pb ultra,going to florida next march seems to have used next years budget up KIDS :laugh: .
    Cheers Gonzo.
  3. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    I've listened to a PCi and a PC ultra in my very small room at low volumes and I think Tom is mistaken to say they sound the same. They have a similar sound, but the Ultra is much better IMO. Many people who have upgraded to Ultra drivers agree with me.
  4. Smurfin
    Smurfin
    Aug 13, 2002
    21,442
    +4,386
    I agree there...the Ultra has a different sound, though my opinion is skewed as I haven't listened to them both in the same room.
  5. funkmonkey
    funkmonkey
    Sep 5, 2004
    107
    16
    Sheffield
    The Ultra driver does look very beefy indeed.
    Has a superb 'I'm over-engineered' look to it.
    Reminds of the insane drivers that SPL freaks use in ICE installations - which is a good think in terms of distortion and SPL's :)
  6. Nimby
    Nimby
    Jan 27, 2004
    9,204
    The Danish Bacon Factory
    +671
    I'd value some opinions on how the larger 16-46 enclosure and single 4" port would suit the Ultra driver. :)
    In the 16Hz tune I feel the Ultra drive unit is being strangled by the smaller port area. As only one of the three reflex ports is then available. This is indicated by the lower maximum SPLs. So the 16Hz tune must surely be a slight compromise. At the higher frequency tunings the Ultra in its 20-39 enclosure must be able to breathe more easily through the greater cross sectional area of the two (and three) open ports. This is indicated by the increased output. But at slightly higher frequncies.
    My feeling is that (perhaps with some adjustment to length for tuning) the single 4" (16-46) port would allow the greater volume of the 16-46 to achieve higher maximum SPLs from the Ultra driver but still retain the very low 16Hz tune.
    Of course we can only guess at the TS parameters for the Ultra driver. Unless someone with experience in these matters would care to run some 'guesstimate' numbers past us? :smashin:
    It's all guesswork on my part of course. But I find it interesting that while a 16-46 Plus is available no 46" version is offered in the Ultra spec.
    Nimby
  7. Ian J
    Ian J
    Aug 6, 2001
    25,630
    +4,906
    Perhaps it's done to keep down the number of models being manufactured and if the purchases made last year by forum members were representative the 39" model outsold the others by ten to one.
    There is one person who undoubtably knows the answer so email Tom and ask him
  8. Nimby
    Nimby
    Jan 27, 2004
    9,204
    +671
    I can't see how pre-sized tubular enclosures in the PCi and Plus ranges couldn't easily become Ultra fodder. They are already in the same factory ready for assembly. :cool:
    Asking Tom would be cheating Ian. :D
    It's much more fun to speculate about these things. :)
    Nimby
  9. Ettepet
    Ettepet
    Feb 7, 2003
    739
    The Netherlands
    +19
    Here you can find an imo better explanation of the difference between these drivers, by Ed Mullen (and quotes from Tom V.):
    On a side-note: The fact that the voice coil of the Ultra is "underhung" could mean it should be mounted horizontally for it to work at its best, making the B4-Ultra a less-ideal option. (the B4 design has all 4 drivers mounted vertically) From what I heard Tom, after the spectacular designing succes of the B4+ tried to use the Ultra-drivers, but found it wasn't worth offering the option.
  10. Smurfin
    Smurfin
    Aug 13, 2002
    21,442
    +4,386
    Well you learn something new every day:) Good post ettepet:)
  11. Ettepet
    Ettepet
    Feb 7, 2003
    739
    The Netherlands
    +19
    Thanks, Smurfin! ;)
  12. Nimby
    Nimby
    Jan 27, 2004
    9,204
    +671
    I don't believe an underhung voice coil knows whether its drive unit is horizontally or vertically mounted. :)
    It just means that the coil is shorter than the magnetic field. The idea being to keep the magnetic motor effect as even as possible over the complete cone excursion. :)
    If the coil was the same length as the magnetic gap. Then some part of it would pass right out of the magnetic field at the limits of cone excursion. Leaving the coil (and attached cone) unable to be driven (or controlled) with the same power at all points on its travel. :oops:
    An overhung coil is much longer than the magnetic field. The idea here is that at least some part of the coil never leaves the magnetic field. So again the electromagnetic power to drive and control the cone. Remains the same throughout the cone's complete excursion. :)
    Regards
    Nimby
  13. Ettepet
    Ettepet
    Feb 7, 2003
    739
    The Netherlands
    +19
    Well you learn something new every day! ;)
  14. Daneel
    Daneel
    Dec 5, 2002
    2,843
    68
    London
    +8
    I'm believe custom versions may be possible. A guy was asking about a 16-48 with Ultra driver and it went to email without giving anything away.
    All of the above info looks like it was copied from posts on HTF. That forum has a wealth of information about SVS.
    A picture is worth a 1000 words as they say, I linked to the thread on HTS some time back showing the old ultra driver (pretty close to the current plus driver) next to the new Ultra driver. The old ultra was dwarfed and looked decidedly wimpy.
  15. Nimby
    Nimby
    Jan 27, 2004
    9,204
    +671
    I think you must mean this picture! :D
    Borrowed temporarily from the SVS forum HTSpot sticky. :blush:
    Nimby
  16. Nimby
    Nimby
    Jan 27, 2004
    9,204
    +671
    An interesting comparison between the SVS Ultra and this 1929 B&O cinema speaker. :devil:
    Nimby
  17. Smurfin
    Smurfin
    Aug 13, 2002
    21,442
    +4,386
    [​IMG]
    And that, people, is where the extra cost is going :devil:
    That is a SERIOUS driver....
  18. Daneel
    Daneel
    Dec 5, 2002
    2,843
    68
    London
    +8
    Way to link the same picture Nimby did on the last page Matt. :p
