Differences between sky+ boxes?
Discussion in 'Sky Digital TV Forum' started by Triggaaar, Sep 22, 2003.
  1. Triggaaar
    Triggaaar
    Apr 13, 2003
    5,592
    +1,022
    Now the £10/month fee has gone, I'll be getting sky+
    Is there any difference between the boxes available? I see from other threads that a V2 is best, but are the boxes from different manufacturers the same quality?
  2. shawkins002
    shawkins002
    Dec 12, 2002
    236
    Epsom, Surrey
    So far the only Sky + boxes on the market are the two Paces. V2 is smaller than the v1 (and IMO looks better, but this is up for debate). Other than cosmetics, the box's operation and functionality is exactly the same. V1 owners are on a slightly newer software version, but I don't know what the differences are - presumably nothing much, and once the dual record update is released I expect they will be the same version on both boxes.
    Other manufacturers have Sky+ boxes in the works (Amstrad I think), but I doubt they'll be out for a while yet.
    If you order now from Sky you'll get a v2 Pace box, which occasionally has the usual Sky+ bugs, but in general works great.
  3. bazzae123
    bazzae123
    Mar 10, 2002
    314
    16
    shawkins002 M8
    Can you check your PM
    Bazza
