Differences between Imports & UK
Discussion in 'General TV Discussions Forum' started by Jpfahy, Apr 23, 2003.
  1. Jpfahy
    Jpfahy
    I'm about to purchase the Panasonic TX-36PL30'C' from Quality Electrical Direct link.
    I wanted to ask, since they are offering the set for a good bit cheaper than their nearest competitor :DPricerunner list here is there a possibility of this set being a so called 'grey' import item. What would this entail, I mean, does it mean the set is inferior in any way? :confused:
    Jpf
  2. ryanos
    ryanos
    Nov 17, 2002
    266
    +3
    don't think so i've got a Sony 32fx66 and i'm fairly sure its an import and I have no compliants at all and at the time it was a good 150-200 quid cheaper than the likes of c*met
