difference in quality between ATRAC3 and ATRAC3plus
sk79
I've always converted and transferred my mp3 collection as 132kbps ATRAC3 files, but a friend said that I should use ATRAC3plus at 128kbps as the sound quality is better despite the higher file compression.
Is this true? I thought that the only difference between ATRAC3 and ATRAC3plus was the different bitrates?
C
Castar
Atrac3+ is better. But you must check with the bitrates that your device supports because 128kbps Atrac3+ is very new. For example the PSP supports it while the NW-HD5 does not (hopefuly, not yet).
drmoze
No, not at all. Atrac3plus uses a different encoding algorithm (OK, a modified one) than Atrac 3, which is improved. It's not jsut a different biitrate, as either format can be used at several bitrates.
In fact, Atrac3+ at 64 kbps is probably moe comparable to Atrac3 at 132. (Both of these work onan HD5.) Atrac3+ at 128 should sound a lot better.
I wouldn't even say that Atrac3+ at 128 is "more compressed" than Atrac3 at 132, although technically it is true by a slight amount. For all intents and purposes, they are pretty much the same level of cmpression.
C
ChunkyMunkyLuva
so if i was to convert all of my music from mp3.. which one is better for sound quality and size and works on my HD5?
drmoze
Well, any Atrac may sound a bit worse when transcoding. Your (smaller filesize) HD5 options are Atrac3+ at 64 or Atrac3 at 132. (No Atrac3+ at 128 on the HD5, next one up is at 192).
I would try converting to Atrac3+ at 64. Then transfer BOTH the original mp3 and the Atrac 64 version (labeled separately). Listen to both. If the Atrac sound sjust as good to you, then I would convert. If it sounds worse, I would just keep files in mp3 format.
drmoze
I don't have all the technical details, but Atrac3+ is an improved (newer) version of Atrac3, which ws made to sound "better" at lower bitrates. The general consensus is that Atrac3+ at 64 kbps sounds roughly as good as mp3's at 128 kbps. Exact comparisons will depend on your player, headphones, if you play back thru a stereo, etc.
(For me, I couldn't discern much difference on my HD5 between Atrac3+ at 64 kbps, 192 kbps, and mp3's at 128 kbps, so I went with Atrac3+ at 64. I listened using 3 different headphones, including my full cans, and so maybe it's my hearing that's shot but the 64 rate sounds fine to me still!)
Atrac encoding has been around for a while and is prevalent on SOny minidisc systems. I think if Sony made Atrac3+ an open format it could have taken over mp3 as a preferred format for low bitrate digital music. But they are keeping it proprietary.
Trending threads
