Difference between Tosh 32ZP38 & 32ZP48
Discussion in 'General TV Discussions Forum' started by StuartC, Oct 25, 2004.
  1. StuartC
    StuartC
    Oct 25, 2004
    4
    Is the difference between the two that the ZP48 is just a newer model?? Has either got any features that are better than the other??
    Stuart
  2. El kiddo
    El kiddo
    Oct 14, 2004
    11
    London
    well 2 RGB-enabled scarts in the '48 as opposed to only 1 in the '38 and the Invar Mask that seems to improve on the whites, it also seems to have done away with much of the problems that dogged the '38 if the personal reviews on the '48 thread are anything to go by. I'm seriously considering getting one for meself in the immediate future
  3. red16v
    red16v
    Aug 20, 2004
    552
    +5
    I cannot recommend the 32ZP48 highly enough. regards, yt.
  4. Londondecca
    Londondecca
    Dec 21, 2003
    2,102
    +104
    I did find a quote which said the ZP had twice as much memory for processing as the old model but I cannot remember which site it was on.
