Difference between SATA and SATA II?
Discussion in 'Desktop & Laptop Computers Forum' started by Frazal666, Jul 21, 2005.
  1. Frazal666
    Frazal666
  2. shaithis
    shaithis
    Feb 25, 2005
    1,668
    The Last Aerie
    +31
    SATA II was supposedly being made to make SATA drives more appealing to enterprise users (i.e. to be used in servers)..
    As far as I know, they are the same as SATA I drives but support a few additional features, 2 are useless to desktop users but 1 feature (native command queuing) can be useful.
    Unless there is no or little cost difference or you are building a server and/or want to use redundant controllers, then I would stick to SATA I.
  3. Skunkpipe
    Skunkpipe
    I didn't think Native command queuing was necessarily a SATAII thing. I maybe wrong.
    For SATAII the bandwidth has been increased from 150 to 300mbps - but you won't see any performance increase as most drives give little over 50-60mbps throughput anyway
  4. Frazal666
    Frazal666
    ok, ill just stick to 1.
    cheers
  5. mjn
    mjn
    May 24, 2001
    22,086
    Herts, England
    +9,831
    NCQ is available on both SATA and SATA-II, but the main difference, as already mentioned, is the increased bandwidth from 150 to 300mbps.
  6. Maff et1
    Maff et1
    This might help: http://www.serialata.org/docs/SATA II Why paper.pdf
    Main thing is 300MB/s vs 150MB/s and support for multi end point cables (allowing more than one drive per port), this, and the 300MB/s will be usefull for raid cabling.
    For most people it's not an issue.
  7. probedb
    probedb
    Aug 20, 2003
    2,654
    Sheffield
    +180
    The board supports SATA-II so you may as well take advantage. I did, Hitachi drive with 3Gbps and NCQ I believe :)
  8. Frazal666
    Frazal666
    Im not going to use raid, so I will not find it useful. Anyway, even if I do use raid, wont 150mb/s still be efficient enough? If a hard drive's bandwith is about 60-70mb/s, the maximum that two hard drives on a raid confuguration will only use 140mb/s.
    I could be wrong, so please correct me if I am.
  9. Skunkpipe
    Skunkpipe
    No that's correct - HDD's will get quicker - and there are already very fast drives out there so they're just building some headroom into the standard
  10. probedb
    probedb
    Aug 20, 2003
    2,654
    Sheffield
    +180
    From tests of the drive I've seen, you really only see the 3gbps as a peak hit on file transfers, but it's basically just that little bit quicker in day to day use even without RAID, plus the drive wasn't exactly more expensive.
