Difference between Samsung 46l6hx & 46l3hx
Discussion in 'General TV Discussions Forum' started by Jonesey, Aug 29, 2005.
  1. Jonesey
    Jonesey
    Dec 10, 2004
    343
    28
    London
    +29
    Does anyone know why Samsung have changed the model number on this tv?
    You can buy the l6hx for £1200 online, but the original l3hx is still priced at £1800, is the newer model a lower spec'ed budget version?
    Any feedback would be appreciated.
  2. neilmcl
    neilmcl
    Oct 29, 2004
    6,236
    103
    Nottingham
    +292
    Samsung haven't just changed the model number, it's a completely new TV. The main difference bewteen the two is the L6HX uses the newer HD4 chip and also IMHO has a much nicer design. It's cheaper yes but this is the natural way of things as technology matures. I suggest you use the search facility to get more information regarding this set.
  3. Jonesey
    Jonesey
    Dec 10, 2004
    343
    28
    London
    +29
    Thanks Neil, Do you know if the Manual for this set is available to download?
    I have checked the Samsung site but can only get a brief description of the tv set only.
  4. Tarbat
    Tarbat
    Oct 15, 2003
    2,512
    Easter Ross, Scotland
    +251
  5. Jonesey
    Jonesey
    Dec 10, 2004
    343
    28
    London
    +29
    thanks cjgpers.
