Difference between KV32FQ75 & FX66?
Discussion in 'Televisions' started by CarlosTheJackel, Dec 4, 2002.
  1. CarlosTheJackel
    CarlosTheJackel
    I can get a both for £900 New but apart from no DPC on the FX66 i can't find a difference (not on the sony site anyway!). Anyone know?
  2. CarlosTheJackel
    CarlosTheJackel
    Well i've found that the KV66 has DPL but I've got a STR-DB1080 amp anyway, then theres the remote finder and thats it I reckon!
    More importantly does anyone know which has the best picture?
    And does every FQ75 have a Scroll Bar problem as I could not see any in the 3 sets I looked at today:confused:
  3. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    Significant numbers appear to be affected. Under which conditions were you viewing ?
  4. CarlosTheJackel
    CarlosTheJackel
    Just shop conditions, they only had the aerial cable attached but that was it. I don't actually know what conditions cause this although I am currently reading
    and its 5 million pages;) But other Sonys appear to suffer this aswell accorinding to the thread:confused:
  5. CarlosTheJackel
    CarlosTheJackel
    OK I've read the first 30 pages and the last 4 and it appears to be an effect of the DRC on the FQ so the FX not having DRC should be ok (maybe):rolleyes:
  6. kennrc
    kennrc
    To my knowledge, the FX66-serie is not affected by the "scrolling bar problem".
    Some FX-66's do however have a minor geometry issue (se other posts regarding this in this forum).
    Otherwise it is a really great TV !!
