Difference between i.Link and Digital Optical input/Digital Coaxial Input
Discussion in 'AV Receivers & Amplifiers' started by Arshad, Nov 19, 2003.
  1. Arshad
    Arshad
    What is the difference between i.Link and Digital Coaxial/Digital Optical input?
    I believe they are all digital so how is i.Link different than the other two?
    Any suggestions?
    Thanks in advance.
  2. ailean
    ailean
    i.Link is the only one able to carry full 24bit/192Khz audio and multichannel 24bit/96Khz from SACD and DVDA. And at least on the Pioneer kit also includes a clock sync feature to prevent jitter between components. You can also daisy chain multiple devices in an i.Link 'network' and each identifies its self by name, so with just 2 i.Link ports on each box you can link dozens of devices.
    To keep the distributers happy it also encrypts the audio and hence the full high res audio support is allowed legally.
  3. Arshad
    Arshad
    ailean,
    Thanks alot for the info.
    i.Link is the only one able to carry full 24bit/192Khz audio and multichannel 24bit/96Khz from SACD and DVDA. Does this also apply to the DVD Video?
  4. ailean
    ailean
    Not sure what you mean, i.Link Audio only carries audio signals. It can carry anything from 16bit/44.1khz (CD) upto 24bit/192khz (DVDA). It will also carry DD, DTS etc.
    I think normal COAX/Opti can only manage 24bit/96khz stereo maximum but the record/film suits have made a legal limit for unencrypted audio at around 16bit/48khz so any copy protected disc containing higher res audio will be downsampled inside the player before output on normal COAX/Opti digital.
    For normal CD and DVDV titles i.Link doesn't add anything new apart from the clock sync (which may only be a Pioneer enhancement, but I've not seen enough i.Link gear to be certain yet). But it is a bit more future proof for new standards.
  5. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    I will post much more on this tomorrow :)
  6. Gordon @ Convergent AV
    Jul 13, 2000
    14,201
    +3,036
  7. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
  8. Plump
    Plump
    Feb 22, 2002
    638
    19
    under the bridge
    Should we ignore the thread in advance :)
    Nic do it Nic do it Nic do it Nic do it Nic do it Nic do it Nic do it Nic do it Nic do it
    But don't forget to mention how many crappy silicons and poor implementations may be found around, not even coming close to the max specs, as well as video limitations.
    Uf sticky...
  9. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    Also dont forget to mention if it is true that encrypted audio is not supported by current devices... :rolleyes:
  10. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    well spotted LR, this is the one thing I can't bottomm out at the moment and the reason I have held off upgrading kit at the moment. Will post four plus pages on digital interfaces this afternoon :)
    being voted for a sticky before I have posted is a little too much faith I think. I got very drunk last night and there might need to be some 'editing' :)
