Difference between DVI and VGA
Discussion in 'Desktop & Laptop Computers Forum' started by dUnKle, Oct 23, 2005.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    16,055
    +3,032
    Whats the real world difference between the two
    Its question been asked by a friend who wants to know why he should go and buy a DVI cable to connect his monitor to his graphics card
    my comment of "because its better" just fell on deaf ears
  2. Skunkpipe
    Skunkpipe
    Essentially DVI is digital. VGA is analogue. The analogue signal needs to be 'digitised' to produce an image. Also with digital signals, cable length and quality becomes less of an issue.
  3. HiZ
    HiZ
    Aug 6, 2005
    609
    28
    +25
  4. Mr.D
    Mr.D
    Jul 14, 2000
    11,200
    +1,243
    Actually analogue vga (RGBHV) is far more robust over long distances than DVI.
    Officially DVI is only supposed to be run a couple of meters.You need very expensive cables to run dvi longer than this reliably
  5. kmhtkmhtkmht
    kmhtkmhtkmht
    DVI rocks VGA. VGA signals are all messed up, i.e. when you plug in a CRT you gotta play with Keystone and all that, with DVI the picture is perfect Geometrically EVERYTime. Now that's Gangsta.
  6. HiZ
    HiZ
    Aug 6, 2005
    609
    28
    +25
    Can't use it on my LCD and graphics card cos when i put the tv on standby the pc thinks the display s no-longer connected. When i turn the tv back on i get nothing... Keyboard shortcuts have to be used to re-enable it. Ive gone back to VGA.
    Now thats way way down in the ghetto.... :-(
  7. Mr.D
    Mr.D
    Jul 14, 2000
    11,200
    +1,243
    This is a display issue. There is no reason why a dvi signal should give better geometry than vga.
  8. dekoded
    dekoded
    Oct 30, 2004
    893
    Blackpool
    +45
    I think if it's practical then yes he should use DVI, mainly because this would remove the A/D conversion, although I'm not sure how much the improvement would be visible on a monitor.
    I'm still tempted to try DVI but as my HTPC is under my TV and I need a 10mtr cable run to my PJ I don't really think it's worth the hassle/expense, unless anyone can convince me to spend money on a nvidia 6 series DVI graphics card and 10mtr DVI cable ;) especially as a 10mtr DVI cable run may not even work.
    I think any of my picture quality problems are down to the source material (DVD) more than the output/cable.
  9. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
    It depends on the source & the display device. My wife has two Acer 19" LCD monitors & while VGA is very, very good when we had one DVI & one VGA it was clear that the DVI picture was clearer & sharper. We had to buy a Matrox card with two DVI sockets & now the display on both is fantastic.
    On my Panasonic AE700 projector connecting the PC via VGA gives a noticeably poorer picture than a DVI->HDMI.
  10. jon stallard
    jon stallard
    Mr Wardle, can I just say that you do ask some very interesting questions. Never shrouded in technicality, just straight to the point. Thanks.
    My own view on this is that the difference in terms of a picture' from a PC to a monitor is that they are both good, especially if you are sat up close to the monitor. It's the resolution that gives you a good picture in either case I think.
    However, in terms of watching TV or DVD on a monitor, especially from a distance (as in a HTPC) VGA tends to be duller, DVI gives me a brighter more vibrant picture. I tried it on an LCD in my bedroom with both connections so DVI is my preferred choice.
    Having said that, the analogue equivalent of DVI isn't VGA, it's component and to be honest, component is the equal of DVI IMHO, it's just that DVI carries with it that copyright handshake malarkey thing which can cause some DVD's to be rejected. A most distressing experience if you've lovingly built a HTPC and stumped up for the original DVD.
    Jon.
  11. HiZ
    HiZ
    Aug 6, 2005
    609
    28
    +25
    Thought it was HDMI which carried copyright info.....? You can get cable converting DVI-D to HDMI cos i've got one.
  12. Mr.D
    Mr.D
    Jul 14, 2000
    11,200
    +1,243
    Yes absolutely right. HDMI is essentially a dvi video signal with some copyright flags and the ability to output additional signals through the one connector. (audio , information flags about the video etc).
  13. Mr.D
    Mr.D
    Jul 14, 2000
    11,200
    +1,243
    I wouldn't say component is the analogue equivalent of DVI. DVI is I believe digitally encoded 8bit rgb as opposed to digital yuv. The analogue would be an RGB format and the highest quality analogue rgb format is RGBHV which is what you get from a bog standard vga connection. Its effectively the digital output of the graphics card without running it through a digital to analogue convertor ( to get VGA).
    And as already mentioned DVI doesn't have copy protection . HDMI does.
  14. MarkE19
    MarkE19
    Aug 10, 2002
    17,617
    Rainham Essex
    +2,546
    DVI 'can' carry HDCP but doesn't always, especially when output from a PC. HDMI however is 'required' to carry HDCP as part of its specs.
    Mark.
  15. Kramer
    Kramer
    100% bang on :smashin: .
