Difference between Celestion S80 & Paradigm 1000
Discussion in 'Subwoofers' started by aqureshi, Mar 26, 2002.
  1. aqureshi
    aqureshi
    Can't decide which one to buy to go with my M73 set.
    Any advise?
    Asad
  2. Markster
    Markster
    From what i am aware the Celestion is more subtle than the Paradigm and may fit in better with the M73's. The Paradigm i believe is a lot more bassy. The only way to know is to audition them yourself.
    I also have the M73's but didnt feel those 7 year old cheap subs would not do them justice so decided to save and go for a rel.
    hth
    audition audition audition
  3. mitch316
    mitch316
    i got the s80 from richer sounds for £80 a couple of weeks ago.i took it back today and paid an extra £40 for the paradigm pdr10.all i can say is there is a massive difference between the two.with the paradigm you can actually feel the bass.as the above post says the celestion is subtle but if you want big bass go for a pdr10.
