Difference between Barco 708 and Cine 7
Discussion in 'Projectors, Screens & Video Processors' started by tryingtimes, Feb 20, 2001.
Thread Status:
Not open for further replies.
  1. tryingtimes
    tryingtimes
    Feb 15, 2001
    4,094
    +531
    Hi guys
    Still looking! Will I ever be satisfied? [​IMG]
    Is the Cine 7 just the updated version of the 708 or has it got any home cinema specific differences?
    It certainly seems to be marketed at more of a domestic market.
  2. Jenz
    Jenz
    Technically speaking the 708 is End Of Life ie a discontinued product. The Cine 7 is the replacement. They share alot in common but basically you need to go thru the specs:
    Barco Cine 7: http://www.barco.com/projection_systems/products/product.asp?GenNr=341
    BarcoVision 708 Discontinued (Mine): http://www.barco.com/projection_systems/products/product.asp?GenNr=129
    BarcoData 708 Discontinued: http://www.barco.com/projection_systems/products/product.asp?GenNr=317
    Hope this helps.
    Regards Neil.
    Webmaster,
    http://www.bulletsnbabesdvds.com
Thread Status:
