QRIO
Established Member
I have been comparing these two amps from what I can see there isn't much of a difference.
All I see is the bass has a little more weight and it sounds a little open. Compared to a 100x5r, I don't understand what the fuss is all about regarding 250x3R compared to 100x5R.
The only thing I haven't tested is at high volume levels. As the power supply caps / transformer in 250x3r are larger. Would we see the 100x5r straining, at what volume level?
Conclusion so far is, if you've got easy to drive speakers and listen at normal levels. Stick with a 100x5r!
