Diff between JVC AV28WFT1 & AV28FT1EK?
Discussion in 'General TV Discussions Forum' started by jawa, Mar 4, 2002.
  1. jawa
    jawa
    Hello,
    I want to buy a JVC 28" widescreen TV, and after reading these forums for some months now I have almost definately decided to buy a JVC AV28WFT1. I have also seen a JVC AV28FT1EK for practically the same price. Does anybody know what the difference is? Is it something like one has dolby pro-logic and the other is just Nicam Stereo?? Maybe one is a slightly newer model. I would imagine the picture is the same....
    I had a look at the AV32WFT1 in Dixons today and it seems like a very nice set, and is very good value for money compared to Panasonic, Sony etc tv's......
    I find all these model numbers confusing.
    Thanks for any help. :)
  2. shez316
    shez316
    Feb 25, 2002
    117
    +3
    I'm sure they are identical. The Pro Logic version is called the WFR1.
  3. goonie007
    goonie007
    just ordered this tv myself today
  4. Russell
    Russell
    The EK bit just means it's a UK model.
  5. jawa
    jawa
    Thanks for your replies :)
    I emailed JVC yesterday and got a reply back today. Is said:
    These two models that you have mentioned are the
    same. Please make sure the model you buy has AV-28WFT1 code (rest of the
    suffix not relevent to the specification of the unit).
    I was going to get the TV from miller brothers (www.millerbros.co.uk) as i can get a discount and they list the TV as "AV28FT1EK". Should I just ignore JVC's comments and get this one? QED also list this model number? Why is the "W" missing from the model number?!!
    God knows why JVC chose to use 2 different model numbers for the same TV!!
    Can anybody confirm that this TV is one of the best 28" widescreen tv's around? I was going to get a Pany PL1 but apparently there are some problems with them...
  6. SILVERBACK
    SILVERBACK
    Aug 13, 2001
    3,836
    71
    birkenhead
    +74
    www.empirdirect.co.uk have the same set for 700 quid mate not sure about the company though.i think i remember a thread saying they are good if they have the stuff you want if they dont they aint to hot.pretty good saving though so i would be tempted try a new thread to c if anyone has a review of empire direct.good luck with your purchase mate :D
  7. SILVERBACK
    SILVERBACK
    Aug 13, 2001
    3,836
    71
    birkenhead
    +74
