Die Hard Trilogy Box Set
Discussion in 'Movie Forum' started by Dave P2001, Aug 16, 2003.
  1. Dave P2001
    Dave P2001
    Jan 2, 2003
    69
    Irl
    +9
    Just seen this at PLAY for £14.99.
    http://www.play.com/play247.asp?page=title&r=R2&title=128585
    Due for release on 15/09/2003, seems like great value but I suppose that they are the versions with just DD 5.1.
    Has anyone got the special editions with all the extras and DTS, are they worth getting.
    All comments appreciated,
    David.
  2. Marv
    Marv
    Jun 7, 2002
    2,832
    Kekistan
    +1,071
    The special Edtions are great, Die Hard and Die Hard :3 have the best DTS tracks out of teh three of them. If you get Die Hard 3 make sure you get the R1 as the R2 is cut. Since the Boxset is an 18 i hoping that the Uncut Die Hard 3 is released with it.
  3. Little Badger
    Little Badger
    The R1 SE has some 'studio cuts' which were made in the fight sequence between McClane and Targo (the chain whipping part)!
  4. Smurfin
    Smurfin
    Aug 13, 2002
    21,428
    +4,376
    I doubt it, it means resubmitting Die Hard 3 for certification.
    The reason it will be an 18 boxset is because Die Hard 2 was always an 18 on its home release (uncut).
  5. Marv
    Marv
    Jun 7, 2002
    2,832
    Kekistan
    +1,071
    It will be an 18 anyway cause Die Hard has always been an 18, Die Hard 2 was a 15 when it was released at the cinema with cuts, but the dvd is uncut 18
  6. LDR
    LDR
    Apr 1, 2002
    2,332
    Wales
    +101
    The R2 version of Die Hard 3 does not feature a DTS soundtrack at all.
  7. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    fantastic set - worth getting at any price - The DTS on DH3 is awesome.
    Gary
  8. Herbal
    Herbal
    If i'm right you only get this on the R1 6 disk set.
    :lesson: :smashin:
  9. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    yes thats right you can only get it on R1 - but it's worth it in the long run.
    Gary
  10. Quinnsey
    Quinnsey
    Jan 11, 2003
    145
    16
  11. Desticado
    Desticado
    Oct 16, 2000
    1,477
    41
    Canterbury, Kent, UK
    +6
    The extras on the 6 disk boxset are worth watching.
    My faveourite bit is the cast n crew laughing their butts off as Willis takes several takes trying to break a window in the first movie. At one point the Chair he's using to try n smash the window breaks, without even making a dent on the window :laugh:
    Regards
