Die another day DTS soundtrack????
Discussion in 'Movie Forum' started by maggi, May 6, 2003.
  1. maggi
    maggi
    Hi there
    Can anyone confirm if the DTS sound on the UK edition is ES Matrixed or Discreet?????
    The reviews i´ve seen don´t state anything on this matter,so i come to the best place to get it sorted.
    Thankx
    Maggi
  2. shodan
    shodan
    Dec 11, 2001
    11,593
    shoeburyness
    +6,520
    The back of the case just says Dolby Digital Surround Ex and DTS-ES.....
  3. akan7
    akan7
    Dec 11, 2002
    327
    28
    England
    +63
    just play my m8 r2
    on denon 3801
    an it's ES Matrixed
    r be getting the r1
  4. maggi
    maggi
    Thanks akan7
    It´s what i suspected:rolleyes:
  5. DanAshmoreUK
    DanAshmoreUK
    Just thought id say that the Dolby Digital EX is properly EX flagged into 3/3.1 using my SONY STR1080:D
  6. sonny
    sonny
    Feb 25, 2001
    420
    Loughborough, Leicestershire.
    +16
    I also have an STRDB1080 and the dts and DD track was similarly flagged SURR BACK DECODING, 3/3/1 which is a little confusing as both are matrixed and therefore not strictly 3/3/1. A film like Blade 2 or Gladiator R1 however is correctly flagged by the 1080 as "SB DISCRETE DECODING 3/3/1.
    IMO the former are still 3/2/1.
    Any views on this.
  7. sonny
    sonny
    Feb 25, 2001
    420
    +16
    Any views on this.
  8. CarlB
    CarlB
    Jan 8, 2001
    1,292
    Cambridgeshire
    +222
    Whilst a little strange I think the display on your amp is fine, it is showing the *decoding* method, not the encoding format. This means the claim of 'DECODING 3/3/1' for the EX/ES matrix source is fine, it *is* decoding 3/3/1 even though the encoding is 3/2/1.
    As it differentiates the DISCRETE decoding I don't really see that the amp confuses the issue.
  9. sonny
    sonny
    Feb 25, 2001
    420
    +16
    On reflection you are probably quite correct.
  10. museumsteve
    museumsteve
    Jan 28, 2001
    7,919
    4
    Nth Hampshire
    +1,070
    doh,. well I got the Reg 2 and it seems to be matrixed..:( a little gutted to say the least.
    Is there confirmation that the Reg 1 will be the real deal though..
  11. akan7
    akan7
    Dec 11, 2002
    327
    28
    England
    +63
    look like the r1 will also be dts ES Matrixed (still be gettin r1)
    on futureEnt.com http://www.futureent.com/dvd/details.php?id=9589
    Sound - dts 5.1 ES ( not dts 6.1 ES as on Blade 2)
  12. PaulBoy
    PaulBoy
    Jul 14, 2000
    1,735
    Surrey UK
    +87
    according to dvdfile.com the dts-es is matrix & they are usually reliable ...
  13. robocop
    robocop
    Oct 16, 2000
    648
    Old Detroit a.k.a. Chippenham. Wilts
    +23
    I bought the R2 version which had DTS 5.1 ES Matrix soundtrack.
    Then I found our that the R1 version is DTS ES Discrete 6.1, so I sold my R2 copy and ordered R1 (sad git I know).
    The R1 copy arrived today, put it on and bugger me, it's 5.1 ES Matrix also:-(
  14. hamtaro
    hamtaro
    thought i would give the veloydyne vx10 an intoroduction to this movie. just like the cinema ,the bass was ear bursting!also i found the speech a little to quiet?i only used normal dts, and will test the dolby version shortly, like i said before the dts soundtrack was a little too intense.
  15. Family Guy
    Family Guy
    DTS 5.1 ES
    DTS 6.1 ES Discrete.
    I defy anyone to tell the difference between the 2 in a blind test. Ideal disc for this is Gladiator or Chicken Run. Both R1 versions are ES Discrete whilst R2 versions are in fact 5.1 ES.
    Flame Suit on....heads for door...awaits slagging of a lifetime...
  16. Lux
    Lux
    Nov 10, 2002
    759
    Luxembourg
    only having 5 speakers and a sub I have no idea what the difference is:
    so what is it??
    I assume DTS ES matrix is the 6th speaker is just a mix between left and right behind?
    And Discrete: 6th channel is encoded as 6th channel independent of other 2.
    Is the difference actually noticable?
