Diddy kong racing help
Discussion in 'Nintendo Forums' started by mojojojo84, Apr 22, 2007.
  1. mojojojo84
    mojojojo84
    Mar 28, 2006
    165
    +7
    if anyone could help with this id be very greatfull,
    by the light house theres to coconut palms that you can fire coconuts from, ive made 3 holes in the rock face across from them. do i just need to keep fireing coconuts at the holes till they get bigger or is there something else i need to do?
    not sure why i was doing it was just messing around and i ended up with the start of 3 holes in the rock face.
    Many thanks
    Lau
  2. coluigi
    coluigi
    Jan 9, 2007
    1,290
    Manchester
    +86
    They do nothing, expect fire out a few blue coins. So don't concern yourself with them.
  3. mojojojo84
    mojojojo84
    Mar 28, 2006
    165
    +7
    oh ok was hoping for something more exciting.
    thanks for the help
  4. coluigi
    coluigi
    Jan 9, 2007
    1,290
    Manchester
    +86
    The thing up the beach which you can draw on is more exciting. You can draw a circle 5 times to get coins, draw a balloon shape for a balloon and draw a pentagon (upside down if my memory is correct) to get a scratch card.
  5. mojojojo84
    mojojojo84
    Mar 28, 2006
    165
    +7
    done that bit, am in the process of trying to fire frogs at the frog shape on the rock face.
