Did my NAD C325BEE just blow my speakers?
MrBuffy
I think my NAD C325BEE has blown my speakers. One isn't working at all, the other only plays from the woofer. Don't judge me, they're ancient JPW Mini Monitors and I love their sound. Bass was being delivered by a Wharfedale SW150.
I wasn't around when it happened and nobody is reporting hearing a 'pop' or anything.
Should I trust the amp and simply replace the speakers, or get the amp checked out?
Thanks in advance.
3rdignis
Have you checked speaker wires, jumper bars, internal speaker wiring.
It's possible you had a tweeter out on one speaker without noticing, then the other speaker going out caused you to check.
You could try swapping channels and/or tweeters.
Have you got a multimeter?
MrBuffy
No multimeter. One speaker is completely dead and I think I would have heard that earlier. I'll take them apart and see if there's anything obvious.
