diamond Interference on Sky
Discussion in 'Sky Digital TV Forum' started by kensden, Jan 27, 2002.
  1. kensden
    kensden
    Whether I use my Sky+ box or another Sky box I am getting a diagonal (both ways) pattern appearining on the screeen. I am going from the sky box to an AV amp then onto an LCD projector using IXOS interconnects (composite) Can ayone suggesest a remedy?
    PLEASE
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Try connecting the RGB output from the digibox directly to the projector?
    At least it should indicate if the interference is being generated by the digibox and not the amp which would seem to be the obvious source.
  3. cutes6
    cutes6
    Jan 3, 2001
    795
    Near Leeds
    +26
    Hi I have had a similar problem through the s-video connection on a crt projector - I was getting a diamond shaped interference - any way the solution was to get a good twin coax s-video lead and it has cured the problem. This lead is well sheilded so you may be picking up some electrical interference somewhere.
