Diamond 9's
Discussion in 'Home Cinema Speakers' started by cool hand luke, Nov 3, 2004.
  1. cool hand luke
    cool hand luke
    Anybody had a chance to demo the Wharfedale Diamond 9's yet?
    They look :smashin:
    How would they compare againist the Mordaunts?
  2. allengn
    allengn
    Sep 6, 2004
    104
    Sutton Coldfield
    I would also be interested in any thoughts. I'm presently trying to decide between the Diamond 9's, which are the What Hi-Fi's speakers of the year, and the MS 900 range.
    For what its worth, when I asked in my local branch of Superfi, the assistant commented that he did not think there were are good as the hype, suggested they had had some faulty ones returned, and recommended a package based on the Mission 30 series as a better option.
  3. Antpink
    Antpink
    Jan 18, 2004
    468
    43
    Singapore
    +100
    Interesting comment on returns. Here in good old Singapore the local Mission dealer is about to drop the entire Mission range, except the high end models, on the basis that they have so many returns of the mid and lo end models it's become embaressing for them to even recommend them to prospective buyers, even when they sound very good in the shop. It appears that this ties in with those that are manufactured for Mission in places such as China, and those that are crafted back in the UK. :confused: Are there similar experiences in the UK, I wonder?
  4. aliflack
    aliflack
    Mar 19, 2004
    239
    16
    I've had a quick listen to the 9.1's - first off, they look stunning! Really good wood finish veneer, nice curves...utterly gorgeous.
    As for the sound, well I didn't listen to them for long, but first impressions were good.
    Not as bassy as something like the Monitor Audio B2, but if you've got a sub to carry on where they leave off, who cares?!?
    I'll be having a proper listen to them this weekend hopefully, just waiting for the local hifi shop to re-wire their listening room... will let you know how I get on
  5. cool hand luke
    cool hand luke
    I would be interested in your findings Aliflack,as this speaker package is still not available over here in Ireland and the wholesaler is uncertain if he will have them by December.Its the 5.1 system that im interested in which includes the sub.
  6. aliflack
    aliflack
    Mar 19, 2004
    239
    16
    unfortunately the dealer is next to useless when it comes to AV stuff - the listening room just isn't big enough for surround sound!
    I doubt if they'll have the centre speakers to be honest, but I'll ask especially for ya! :thumbsup:
  7. aliflack
    aliflack
    Mar 19, 2004
    239
    16
    well I had a more careful listen to the 9.1s and also the 9.0s today.
    First off, the 9.0s don't share the same curvaceous styling of their bigger brothers, slightly disappointing tbh. But its the sound that counts, and they sounded pretty similar to the 9.1's, yeah not quite so much bass, but they do pluck out some pretty low notes considering their size.
    As for the 9.1s, they still sound good. Compared to the MS 902's they sound pretty identical. I prefered the mid range of the 902's, feeling it was slightly cloudy in the Wharfedales. Close call though...
    Then I listened to them against the MA B2's - in this test the Wharfedales fared much better. They made the B2's sound overblown on bass and low/mid-range. Plus the 9.1s look sooooo much better than the vinyl wrap of the B2's
    Didn't get to listen to the centres unfortunately :thumbsdow
    Hope that helps!
  8. NMyTree
    NMyTree
    Jun 17, 2004
    105
    16
    Yankville, Whanker USA
    I'm confused.
    Are the Diamond 9.1 and the Diamond 9 Series in general, real wood veeners? Or are they vinyl laminates?
    I was under the impression all Diamond 9 Series are vinyl laminates.
    What's the deal with this? When I spoke with someone at IAG, I was told they are all Vinyl laminates.
  9. aliflack
    aliflack
    Mar 19, 2004
    239
    16
    the B2's are obviously vinyl - really plasticky looking and not a convincing 'wood', the Wharfedales by comparison looking very realistic - not sure if it is a real wood veneer or not, but they look real enough for me!
  10. Tejstar
    Tejstar
    Dec 4, 2002
    22,794
    London
    +1,080
    They are not real wood - the evolution series are though.
  11. NMyTree
    NMyTree
    Jun 17, 2004
    105
    16
    As are the Opus series.......real wood-veener
  12. Diamond
    Diamond
    I can confirm it's vinyl or something, a small piece was torn from the bottom of 9.1, when I lifted it. It was attached to TV with a two-sided tape, too strong I see, especially when TV heats up the glue becomes superstrong. Some kind of mdf under the vinyl. Luckily, the mark on the speaker can't be seen!
  13. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    I heard the 9.4 with 9cs center and 9.1 rears and I found them very good for the price!!!! I couldn't believe the price!
  14. Tejstar
    Tejstar
    Dec 4, 2002
    22,794
    London
    +1,080
    I heard these at the recent What Hi-Fi show and was very impressed. As you said Falp, great value for money.
    They got 4 stars in this months What Hi-Fi magazine.
  15. rombi
    rombi
    :thumbsup: :thumbsup:
    I recently aquired the 9.4 and 9.1 modles as part of a package deal, long with the centre speaker. At first i was a bit hesitant as the 9.4 received only 3/5 in a What Hi-Fi group test. While auditioning both in store i could understand exactly where the reviewer was coming from (claiming that the 9.1 on a good stand would leave the 9.4 dead). The salesman reasures me that both had been run in for over a month so my concern about run in is soon seen to. Somehow the 9.4 seems not to project the sound out and at you, but the sound somehow seemes to get lost within the speaker enclosure. This leaves me puzzled. How could Wharfedale get it so wrong. the 9.1 is singing whereas the 9.4 is struggling to breath probaly.
    it then dawns on me that these are floorstanders designed for small (smaller) rooms (only on mid/bass driver, as oppose to the 2 on the 9.5 and 9.6).
    Well, where is the obvious place to place a floorstander in a small room? Well the corners is where most people would squeeze it in. So to the corners they go and WOW. The once timid 9.4 are transformed. The bass seems to appear form nowhere, suddenly there's a soundstage where there there once was almost none. Now after spending what now seems an eternity in forums like these, these little honeys contradictes everything I thought I had learnd about speaker placement.
    It seems that the guys at wharfedale actually got the sums right after all.
    Floorstander + small room = corner placement = 9.4 = floorstander for small room. :smashin: :smashin:
    I am now a hugely satisfied and proud owner of both the 9.1 and 9.4.
    :D :D
