Dialogue on subwoofer ?
Discussion in 'Subwoofers' started by drphibes, Apr 5, 2003.
  1. drphibes
    drphibes
    Oct 23, 2002
    1,141
    48
    +33
    I have just upgraed today from a Sony 930 to a Denon 3802 amp.
    I am using 4 Mordaunt short 904's ,1 Mordaunt short 905c and a Mordaunt short 907w subwoofer.
    I have connected the various leads and I seem to be able to hear distant speech in the subwoofer.
    I was under the impression that the sub would only deal with sound effects and leave the speech to the centre speaker.
    I s this ok or have I got something wrong here ? , I did not notice the speech with the 930 amp.
    Drphibes
    *UPDATE*
    I have the sub connect using the red/white connectors on the denon out 907 in.
    I unplugged one of these and got no sound , plugged it back in and took the other out and now I have souned effects and no speech in the sub .
    I cannot remember but am I right in thinking that the sub is a mono channel and therefore only needs a single feed?.
  2. damtom1
    damtom1
    There is a single out to the sub,that i use.Have you got it connected to the sub out,and not another pre-out(ie: centre pre out).I did this before and had the surround right feeding the sub,by mistake,it didnt sound too healthy!
  3. Brad_Porter
    Brad_Porter
    Check all your connections. From DVD - AMP - Speakers. You should not get dialogue through the sub. If you are getting it all the time then one of the connections is wrong.
  4. Bapapapa
    Bapapapa
    Jul 24, 2000
    113
    16
    Unless the speaker has a *really* deep voice, of course.. :rotfl:
  5. Brad_Porter
    Brad_Porter
    :D
    Yeah - something like Barry White might have it!!
  6. EvilMudge
    EvilMudge
    Barry White - in which case set your crossover to Lurvvvve.:D
  7. Brad_Porter
    Brad_Porter
  8. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    You'll get male dialogue through a sub if the crossover in amp' or sub is set too high.
  9. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Drphibes im looking into buying a 907 sub and wondered if you would give me an opinion on it please.
    Thx
  10. drphibes
    drphibes
    Oct 23, 2002
    1,141
    48
    +33
    I have been very please with my Mordaunt Short 907:D .
    I cannot really say how it compares to other subs as this is the only one I have owned but it certainly packs plenty of bass and and looks really great aswell.
    Maybe someone else with a little more technical knowledge can come on and give you some more details.
    Drphibes
