DHT-500SD Question
Discussion in 'Blu-ray & DVD Players & Recorders' started by dino25, May 28, 2005.
  1. dino25
    dino25
    Hi has anyone bought the DHT500 SD as a region 2 and tried the software hack for multi-region with success?- have a region 2 myself and havent set it up yet with the thought of having the hack done.
  2. caltune
    caltune
    :( Hi i just downloaded a multi region hack for my dht500 sd, loaded it and i've got a "mecca err" come up, what the heck do i do? the dvd wont work but the tuner and other functions do. I put cd in then it came up erase with a loading bar then write with a loading bar then done, i turned the unit off then back on again and get "mecca err" :lease: help.
