DHE2000 & X1600 Pro Hdmi
Mysterious K
Has anyone put this card in there DHE2000, its just the space is so limited inside, i just want to make sure it fits before buying it. And can finally get my MCE running perfectly on my 436xde after 6 months of messing with powerstrip etc just to get a half decent desktop.
andrewd1
Hi where did you get your card from and have you had any problems with your TV not displaying the pc screen after you have turned your TV off?
DarKHorsE
Mysterious K said:
No problembs at all, very happy. Shows all boot up screens through HDMI port, then open Catalyst set your settings, crystal sharp desktop and working perfect in MCE.
I Bought it from Amazon, i've seen it cheaper but it was always out of or awaiting stock, took 2 days to arrive.
http://www.amazon.co.uk/exec/obidos/ASIN/B000GLDYYM/202-4598067-2816611?_encoding=UTF8
Is the fan on it audible?
Is there a distinct improvement over the original x300 or gf6200 which were both passively cooled?
itsfja
Funny you should mention that ...
When TV is switched off overnight, screen comes up black, only way forward is to reboot PC.
When rebooted the video defaults to 640*480, pstrip corrects but desktop is rearranged. There is some evidence that this is a pervasive issue between ATI and the Pioneer.
BBC HD hardware acceleration present, no stuttering of sound or video but woeful frame rate, 30% free CPU.
Under the ATI I only got two resulting screen resolutions from moninfo
1920 x 540
1920 x 1080
Under the Nvidia I get;
1920 x 1080i at 50Hz (16:9) - HDTV (Native)
720 x 576p at 50Hz (16:9) - EDTV
1280 x 720p at 50Hz (16:9) - HDTV
1920 x 1080i at 59.94/60Hz (16:9) - HDTV
720 x 480p at 59.94/60Hz (16:9) - EDTV
1280 x 720p at 59.94/60Hz (16:9) - HDTV
720 x 576p at 50Hz (4:3) - EDTV
640 x 480p at 59.94/60Hz (4:3) - Default
720 x 576i at 50Hz (16:9) - Doublescan
720 x 576i at 50Hz (4:3) - Doublescan
720 x 480i at 59.94/60Hz (16:9) - Doublescan
720 x 480i at 59.94/60Hz (4:3) - Doublescan
1920 x 1080p at 23.97/24Hz (16:9) - HDTV
In addition, I got a warning that there was an HDMI - DVI connection, there wasn't - just HDMI to HDMI.
I am RMAing the card.
Regards,
Francis.
Mysterious K
The MSI x300 was a nightmare of a card when hooked up via DVI-HDMI on my 436xde always lost its settings, blurry desktop. Always having to hook up a monitor use powerstrip etc. The X1600 was a dream replacement, i cant fault it, and i can't hear the fan.
DarKHorsE
Thanks:smashin:
andrewd1
1920 x 540
1920 x 1080
Regards,
Francis.
The reason I ask is I had the Sony Vaio XL 100 which has HDMI and it was connected to my Panasonic plasma and when i turned the tv off I just got a black screen after turning it back on so I needed to reboot to get the display back.
I ended up returning the pc.
itsfja
Bummer. I really am going off HDMI, it's too complicated for it's own good, with one end or t'other making what appear to be quite poor decisions at times. To reiterate what was said earlier, the fan really was very quiet (I have reverted to my trusty 6600GT (silentpipe) and frankly I couldn't hear the difference from my normal viewing distance of around 15ft even with the TV sound off.
Regards,
Francis.
Similar threads
