Dg834g date/time
Discussion in 'Desktop & Laptop Computers Forum' started by GCDB, Mar 24, 2006.
  1. GCDB
    GCDB
    Sep 23, 2004
    321
    Wrexham
    Dont know if i am missing something and this could be one of those embarrassing posts,and i have RTFM..
    My netgear is showing date 2002,does this matter?
    I cant find anything except it is supposed to update itself and it obviously doesnt,been on for a week,can access internet etc.
    Have tried double clicking on date and cant seem to alter it.
    I am using latest firmware as well.
    Would like to have the log dated/time correct for faults etc.
    Any ideas?Even embarrassing ones?
    Ta
    Gav
  2. dannyg81
    dannyg81
    Nov 23, 2005
    382
    +9
    The Netgear routers retrieve there Time and Date via NTP, a Netgear time server. Have you tried a hard reset, using the reset button at the back? It should try and establish a connnection with the NTP and usually takes about 5 mins. If it still doesn't work, try updating the firmware, as there may be something broken with your current one. I'm running V3.01.25 and everything is fine.
  3. bibamus
    bibamus
    Dec 10, 2005
    1,057
    Suffolk
    +43
    If you decide to upgrade the firmware, download the recovery utility first in case anything goes wrong ( speaks from personal experience :confused: ) My router failed to upgrade properly, a call to netgear support and I was told to download the recovery utility from their website. Brilliant, but I couldnt get on line, the router didnt work..........
    Allan
  4. GCDB
    GCDB
    Sep 23, 2004
    321
    Wrexham
    Thanks but already have latest firmware,will do a hard reset.
  5. bibamus
    bibamus
    Dec 10, 2005
    1,057
    Suffolk
    +43
  6. GCDB
    GCDB
    Sep 23, 2004
    321
    Wrexham
    I did upgrade to the latest firmware, but i have noticed in the routers settings there is a tick box for use this ntp address and it is blank.Could someone please let me know what address is in thiers or would that effect security etc????
    If it is just a case of putting the same address in that might fix it?
    Ta
    Gav
  7. Ray
    Ray
    Oct 2, 2002
    855
    West Yorkshire
    +23
    Mine is blank and the box isn't ticked but is showing the date/time ok. Not sure where it finds the default ntp server on the internet but it obviously does.
    You could try 194.35.252.7 as noted here : http://ntp.isc.org/bin/view/Servers/ChronosCsrNet
  8. GCDB
    GCDB
    Sep 23, 2004
    321
    Wrexham
    Thanks for info but seems to have corrected itself.
    When i checked yesterday,the ntp server checkbox was ticked to say use this one..........etc
    Once i unchecked the box the time corrected itself.Strange though it had been like this probably from the upgraded firmware as only i use the router and had not altered any of this.Why the firmware upgrade had automatically ticked this box i dont know.....?
    Anyway ok now so thanks all
    Gav
  9. dannyg81
    dannyg81
    Nov 23, 2005
    382
    +9
    It was probably pointing to an old ntp server. Odd that it would do this by itself though, like you say. Atleast it's one to remember for future reference :D
