DFGT broken
Discussion in 'Playstation Forums' started by evilkegs, Nov 28, 2010.
  1. evilkegs
    evilkegs
    Sep 2, 2007
    431
    south shields tyne & wear
    +57
    just got my logitec dfgt out to play gt5 and went to plug it in and my stupid wife has snapped the usb cable that plugs into the playstation into three bits is they any way to fix this ?
  2. Kurby
    Kurby
    Nov 7, 2009
    124
    +6
    You should be able to cut another (cheap) usb cable and attach the wires like you would with a coaxial cables (tv aerial). I haven't tried it so I'm not 100% sure it will work.
  3. evilkegs
    evilkegs
    Sep 2, 2007
    431
    +57
    so a usb lead is no more complicated than a tv aerial lead ?
  4. boltlock
    boltlock
    Jul 13, 2006
    7,665
    Home
    +4,248
    As long as the colours match it should be no more difficult than a coax cable. It only has around 4 wires anyway. HTH.
  5. Kaden101
    Kaden101
    Jul 22, 2009
    1,444
    Castleford, West Yorkshire
    +157
    If you're not sure, try "Repair USB Cable" into Google. One of the first ones I found had a link to
    Make a Short USB Cable
    which shows some pictures as a guide. I´m sure you´ll be able to find other stuff more useful.
    Looks like it´s perfectly possible
  6. evilkegs
    evilkegs
    Sep 2, 2007
    431
    +57
    thank you to everyone who replied:smashin: i have managed to solder the four wires in the usb cable back together and bought a usb extension lead to make it long enough and it all works which surprises me with my electrical skills :laugh:
    now to get back to playing gt5
