DF BK Monolith
Discussion in 'Subwoofers' started by Docta teef, Aug 16, 2005.
  1. Docta teef
    Docta teef
    Nov 21, 2003
    1,262
    Manchester
    +56
    Just out of interest does anyony know if there are any plans for a down firing version takl about lack of WAF i dont like its looks as it is myself. (now i should be off to put on a dress with comments like that)
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    I would be very surprised indeed. Changing the driver orientation would probably cause havoc with the port tuning frequency so it would have to be redesigned from scratch again. I could be wrong though :)
  3. BK Electronics
    BK Electronics
    Active Member AVForums Sponsor
    Aug 10, 2002
    376
    Essex
    +25
    I'm sorry there Docta Teef but we are not going to offer a DF version of the Monolith. Technicaly it's possible, as John say's it would need some tweeking. It's more a case of the extra model in 3 finishes that becomes a problem.
    Regards
    Tom
  4. Timmy!!!
    Timmy!!!
    Oct 9, 2005
    105
    +7
    Haha! Guess you changed your plans then Tom! Im pleased you have, because imo the DF looks so much better than the FF version. Top marks for doing it!
  5. BK Electronics
    BK Electronics
    Aug 10, 2002
    376
    Essex
    +25
    Your sins will find you out hey!
    As with all things you have to listen to your customers, and I'm glad to say they are once again on the mark. It certainly looks nice, maybe a little bit easier to get past the financial advisor
  6. andyturner28
    andyturner28
    Hi Dan.
    What are the differences between the FF and DF?
    I am going to be ordering one in the next few days and can't decid which one. Do they both sound the same and if not which sounds the best? I am more interested in sound quality, i don't have another half to please:thumbsdow
    It will be used upstairs on floorboards, would i need to get an isolation pad with the DF.
    Andy
  7. BK Electronics
    BK Electronics
    Aug 10, 2002
    376
    Essex
    +25
    Hi Andy
    With the FF you need to be about 2M away from it for the best effect, but the DF you don't. So if you listen to the two subs side by side and you are quite close the DF sounds slightly deeper than the FF, beyond 2M and with your back turned you cannot tell the difference.
    As for decoupling I would suggest the FF with spikes, but perhaps someone can share thier experience on this
  8. javers
    javers
    Not sure if its relevant since you've got a wooden floor but I'm running 2x Monolith FF's spiked straight into concrete. To my ears this the spikes sound punchier than just the nylon screws onto carpet, which I tried first.
    Jon
  9. andyturner28
    andyturner28
    TWO MONOLITHS?!! How big is your room? I would have thought two of these is good enough for a full size cinema. I would be interested in some pictures of your set up.
    If i stood a DF on a couple of paving slabs would this stop any vibrations being transfered downstairs? (at low volumes obviousely) I really like the look of the DF now and would like to try to make it work in my set up. As i have a radiator at the front of the room it will have to live on the side wall so will be less than 2m from the listening position.
    Dan, what is the lead time on a DF currently, and do you deliver in the evening or weekends?
    Andy.
  10. GrannySmith
    GrannySmith
    Sep 26, 2002
    280
    Pembrokeshire
    +8
    I'd agree with this...only put the spikes on my Monolith to avoid leaving permanent footprints in the lounge carpet, but it deffo sounds tighter & faster this way. Still running it in, but this is one awesome sub...:eek:
  11. GreenEagle
    GreenEagle
    Jan 16, 2003
    Maidenhead
    Can the monolith use the high and low level connections simultaneously like the REL Strata 5?
  12. Timmy!!!
    Timmy!!!
    Oct 9, 2005
    105
    +7
    It sure can!
    Mine arrived today, still boxed up at the mo but tomorrow ill be unpacking it!:thumbsup:
  13. kit1cat
    kit1cat
    Sep 4, 2002
    1,474
    Plymouth
    +86
    No, it only has one Xover. You normally set the xover for high level input and turn it off for low level input. Check previous threads.
  14. Timmy!!!
    Timmy!!!
    Oct 9, 2005
    105
    +7
    Ah, my bad!:rolleyes:
