Question Device to turn ethernet into wifi?
Discussion in 'Networking & NAS' started by Bosee, Apr 26, 2016.
  1. Bosee
    Bosee
    Jul 29, 2015
    53
    11
    bristol
    +3
    I was just wondering if something exists (not a router nor an ap) that can plug into an ethernet port and make a wifi hotspot with it...? am a bit technically challenged so excuse my simpleness :)
  2. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,394
    Norfolk
    +2,406
    That's the very definition of an access point.
  3. OnAMission
    OnAMission
    Dec 23, 2014
    24
    4
    Bristol
    Sorry, am on a different account, do you mean I can just plug in a wireless access point into my wall ethernet outlet?
  4. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,394
    Norfolk
    +2,406
    That depends on what the ethernet connection is connected to on the other end. If it's connected to a router then yes.
    If it's the entry point for the internet into your property then you'll need a router instead.
  5. mickevh
    mickevh
    Apr 30, 2007
    6,996
    West London
    +1,645
    You may not be able to "just plug it in" - it may need some configuration to (for example) give it an IP address, set radio channel, set SSID name and passphrase ("Wi-Fi key") but in a device aimed at the SOHO market, it should be pretty simple.
    If you're really worried, try getting hold of the manual of any prospective purchase and have a read of it to see if you can follow it.
