detoma amp
Discussion in 'AV Receivers & Amplifiers' started by brendank, Dec 17, 2003.
  1. brendank
    brendank
    Dec 13, 2003
    639
    drogheda, co louth,ireland
    +6
    hi all,
    i just came across this amp on ebay and it appears to be ideal for me with a bang olufsen front and rear speakers and tv.
    I was wondering whether any other forum members have used this amp and if yes how have they found it.
    This DolbyDigital Decoder is developed by the german manufacturer and is used with products/speakers that use 8 Pin DIN connectors. Bang&Olufsen calls it the "PowerLink" for all their active speakers. Here some technical specifications:
    DolbyDigital AC3, PCM (Digitalinput)
    Pro Logic 5.1
    Stereo
    8 Pin DIN analog input
    coaxial digital input
    optical digital input
    DC Power 12V
    their website is www.detoma.com followthe arrows to the english site and navigate using the arrows on top a bit confusing at first but then it becomes perfectly logical
    They also make some very nice looking active speakers as well. worth taking a look for that alone
    :rolleyes: ;)
