Detecting DTS?
Discussion in 'AV Receivers & Amplifiers' started by superdon, Jan 8, 2004.
  1. superdon
    superdon
    Dec 31, 2003
    1,717
    48
    +65
    Well,
    We have set up our new gear and are starting to get everything set up. We have a Toshiba DVD player and have that connceted to our Yamaha AX640SE amp via an digital optical cable.
    Everything seems fine with Dolby Digital, but the amp doesnt detect DVD's that have DTS. Also, it doesnt seem to pick up Digital EX.
    What am I doing wrong here? This is the only problem I have had settting up the entire new system listed below...
    Panasonic TX-28PS12 TV
    Yamaha AX640SE Amp
    Modaunt Short Premiere Speaker Package
    QED Original Speak Cable
    THOR scart leads
    Toshiba 220E DVD (rescued off my old system)
  2. buns
    buns
    Apr 29, 2001
    6,085
    58
    Belfast
    how have you got the digital output configured? bitstream or pcm or what?
    ad
  3. superdon
    superdon
    Dec 31, 2003
    1,717
    48
    +65
    on the DVD player? Bitstream.
  4. JIT
    JIT
    Mar 2, 2002
    1,188
    38
    Glasgow
    +8
    Also remember that in the actual movie's audio options you have to select DTS for it to be sent to your receiver.
    Whereas if you just select play DD5.1 may be the default sound format.
  5. superdon
    superdon
    Dec 31, 2003
    1,717
    48
    +65
    Yeah, tried that too. On Lord of the Rins for example, set the DVD to play in EX and still only DD was comin through.
  6. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,560
    Edinburgh
    +1,265
    Do you have 6 speakers hooked up to the amp. If you have told the amp that there is only 5 speakers connected it will ignore the 6th channel.
  7. superdon
    superdon
    Dec 31, 2003
    1,717
    48
    +65
    got it. thanks for that!
    i only had 5 speakers set up on the amp (cos I only have 5 speakers), changed it to 6 and DTS is there!
    maybe I should get a rear centre. if i have the mordaunt short package, whats the best rear centre? A satellite speaker or another centre?
  8. buns
    buns
    Apr 29, 2001
    6,085
    58
    Belfast
    ok...... that puzzles me!? :confused: why would you have to set to 6 in order to set dts? I only use 5 and dts plays fine......
    ad
  9. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,150
    2
    +3,588
    MS304's are available seperately at about £80-100. I have one as a centre rear.
  10. bobbypunk
    bobbypunk
    if you don't know how to set things up get it installed when you buy it. It's much easier.
  11. superdon
    superdon
    Dec 31, 2003
    1,717
    48
    +65
    your joking aint ya - whats the fun in that
