detach tv stand help
dieselblue
my elderly neibour has a 37inch panasonic lcd that seems to be attatched to a glass stand some how and i can fugure out how to get it off as she want a new tv but keep the glass stand.i can detach the tc from the small plastic stand that comes with tv but im then left with the stand attached the the big glass one any ideas how to get it off
John7
I would suspect that the plastic stand is just stuck on the glass by age.
What happens is the pressure from the weight of the TV combined with aging of the rubber cushions on the bottom of the stand have deteriorated (broken down) and become sticky, adhering it to the glass. Try applying more pressure and levering with a wide, thin pry-bar. like a wallpaper scraper or similar. Heating the plastic up with a hairdryer might help loosen it.
dieselblue
thx al try it
RBZ5416
I'd agree with @John7. You could also try twisting the stand with a quick snap. That should break any bond without putting undue pressure on the glass.
Sloppy Bob
What does she want to do with it as from that picture it looks like it's incredibly unlikely it will fit any other TV?
