Detach & reattach hdmi/component cables etc?
lapino
Does any1 know if it's possible/doable to detach the hdmi/component plugs from a cable on one end and then later reattach it (soldering)? I need to put 1 hdmi and 1 component cable in two tubes which are placed in my ceiling but the tubes (damn electrician) are too small to fit the hdmi/component plugs.
(hope this is clear enough)
Joe Fernand
AVForums Sponsor
Hello lapino
You can re-attach RCA and BNC solder-on plugs 'relatively easily' - or alternatively order the cable with one end un-terminated and make the terminations once you pull the cable.
HDMI is not something you can disassemble/reassemble on site - Supra Cables (Jenving SE.) were talking about an HDMI/DVI product you could make up on site; though not sure how much the tooling would cost and I doubt it would be cost effective for a single cable.
You can 'jump' Component onto HDMI - potentially then you would only require a single HDMI cable through your narrow conduit; see http://www.gefen.com/kvm/product.jsp?prod_id=3569
Best regards
Joe
