Desperately need helping connecting sub to amp to pc
1ncubu5
Not sure if this is the correct section, so mods please move if wrong...
Just now I have my AV amp connected to my pc soundcard via RAC-3.5mm cable, only boasting 2 main front speakers at the moment.
Fancied adding a sub to the mix, but cannot figure out how...
connections on sub are:
connections on amp are:
any help or advice would be much appreciated
just realised the pics are upside down and massive...can sort out if necessary :smashin:
davepuma
Makes and model numbers would help. If it's an AV Receiver you have, basically you need an active (powered) subwoofer, which will connect from the AV Receiver's subwoofer pre-out to the Left input on the subwoofer.
1ncubu5
thanks for the reply, it's some old kit I've decided to recycle as a PC setup.
The AV amp is a Yamaha HTR-5540RDS and the sub is a JBL SUB138 according to the back...
davepuma
My answer above stands. The subwoofer pre-out connection is on the left hand side marked "output" according to the manual.
You need a subwoofer cable.
LV426
Administrator
Staff member
On the amplifier - in the picture above - looking at it as is it presented now (i.e. upside down).
Start bottom right and look for a bright orange socket labelled CD2. Go left one and up one and look for a black socket labelled Sub Woofer.
On the sub woofer look for the yellow socket marked LFE.
Connect a single RCA phono - RCA phono cable between these. Does not have to be of any esoteric type, but if it's a long run you may find a "better" cable gives better results. Remember to "tell" the amplifier (in its setup) that you have a subwoofer. And then adjust levels to suit.
1ncubu5
thanks for the reply, turns out the way I'd tried connecting it up perviously was correct - I just needed to activate the LFE crossover settings in my soundcard properties!
Podcast: Marantz SR7015 & NAD T 778 AVR + Mission LX2 MKII Speaker Reviews, AV & Film News and More
