DESPERATE! Samsung E300 unlock???
Discussion in 'Mobile Phones Forum' started by brummyboxer, Jun 18, 2005.
Tags:
  1. brummyboxer
    brummyboxer
    I have just been given a samsung e300 with no which was previously on Virgin but i want to use my orange sim.I put it in and all it says is "wrong card"?
    I havent the first clue about codes or security numbers etc so i just wandered if anybody can help ?
    :lease:
  2. mikeybhoy
    mikeybhoy
    I have just used the unlock code for the e720 and it works on the e200
    . Switch OFF your phone.
    2. Put in a SIM of a different network provider.
    3. Now turn your phone back on. You will see an error message saying
    "Wrong Card".
    4. Type *#9998*3323# in to your phone.
    5. If you've entered the code correctly as outlined in the Step 4, you
    shall see a screen telling you to press exit. So hit the right soft key.
    6. Now you will see a Menu of choices. Scroll down and select option 7
    (“Jump to Null”). As soon as you select option 7, your phone will turn
    black and reboot itself. After your phone reboots, the SIM will be
    recognized and your SIM will work. (Please be patient while your phone
    reboots and DO NOT press any keys.)
    7. Now, at your welcome screen type in *0141# and hit your call button!
    This will give you a message saying your phone is Personalized.
    8. Power OFF your phone and insert your original SIM.
    9. Once done, power ON your phone.
    10. At the SIM Code prompt, it will ask you to enter a password. Type
    00000000, (that is 8 Zero's). After you enter the code, hit "ok" and
    your phone should power up.
    Your phone is unlocked!!!
    You can now put the SIM of your choice into the phone and use it at your
    will! Without ANY RESTRICTION!!!
  3. stephanie
    stephanie
    i tried that unlock code on the e300 and it didnt work?
