Desperate for opinion on new speaker system
Discussion in 'Home Cinema Speakers' started by Col, Apr 25, 2001.
  1. Col
    Col
    I'm looking for a speaker system to go with my newly purchased Sherwood R-956R DD amp, and soon to be purchased Pioneer DV737.
    I was going to go for the B&W S2 system, but heard several reports of it lacking in low-end. A few people recommended the Kef Q65.2 range but then I came across Mordaunt Shorts new THX Select 500 system on http://www.home-entertainment.co.uk/grouptest_read.asp?GroupID=1180&ArticleID=1191 . It doesn't look like demoing them is going to be easy as they're so new and the only place I've seen that sells them is Richer Sounds. They gave the impression they won't be getting them in store for a while. But from what I can see they look ideal. I like the idea of aluminium cones and the 10" subs in the bottom should keep me going until Rel release the Q150.
    Has anyone had any experience of them or anything similar? I don't want to buy 'blind' but need to buy something soon!
  2. Curve_Gavin
    Curve_Gavin
    You'll find richer sounds are the only outlet for Mordaunt Short.As they are with sherwood.
  3. Guest
    As far as I know with Mordaunt Short in particular, Richer Sounds have a "Controlling Interest" shall we say. I think that can also be said for Cambridge Audio and a few others.
  4. Col
    Col
    What do you mean by that?
    Does it mean the speakers are no good?
  5. bigalroz
    bigalroz
    Nov 21, 2000
    53
    Stirling,Scotland
    Col,
    You could try the Tannoy MX range. I have Tannoy speakers and they are excellent, plenty of bass even without a sub, and if you want a sub you pick up the excellent Tannoy MSUB10 or the newer Tannoy MXSUB10 for under £200 these days. Tannoy seem to be relatively easy to get your hands on too.
  6. Guest
    Col
    I assume you are referring to my post although I could be wrong, what I mean is that Richer Sounds either own outright, or own large chunks of the brands it sells, this is by no means saying they are no good, and in fact mordaunt short speakers are regarded as good and have won awards in the past, of course if your question was not aimed at myself then sorry but I hope this info was useful.
    Martin
  7. Col
    Col
    Thanks Martin. I use Cambridge Audio - Pacific interconnects too :)
    I still haven't found anyone who's heard these speakers yet!
