David j Blake
Am hoping there's a kind and clever soul out there who could help enlighten me with my home cinema unit...
I have an LG 3D blu-ray home cinema system (model HX966) which I have had for around 3 years and have always predominantly used it for hooking up my games consoles to. I bought a PS4 yesterday and hooked it up to one of the HDMI out ports and it worked perfectly. Tried it this morning and the player has stopped working, the standby light comes on as normal and I can insert and remove discs but after 20 seconds it turns itself off, back to standby mode. I can't get any menus and It won't let me play any discs be it dvd , blue ray or a normal cd.
The PS4 works fine so could it be I have tripped something in the cinema system via the ps4 or is it more likely just coincidence? I have tried everything, including unplugging all wires, connectors etc and no joy. Have been using my Xbox one and 360 up until now with no problems.
Any help would be greatly appreciated, also if it needs repair does anyone know what a ballpark figure would be? I live in the UK. It wasn't the most expensive system at the time but i still think it cost me around £700 and although i have had good use from it i would still feel a bit short-changed if it had broken already!!
