wardreefa
Established Member
Hi ive had some issues with my desktop these last few weeks as windows took an update and the desktop was meesed up from there.
I gave my desktop to a guy i know who works in I.T and he said the mother board was not finding the drivers for some reason.
He installed a new hard drive with some more memory and a clean copy of vista 64 bit.
When i got desktop back i booted it up and all seems fine and a bit faster due to more memory but after about 1 hour this came up
an unauthorized change was made to windows
X you will no longer recieve notifications , including these about your licence or activation , use the link below to find out how to fix your system
error 0xc004D401
the security processor reported a system file mismatch error
The desktop is still running ok but on some web sites i go on it struggles and in bottom right hand side its saying new updates are available which is this
Windows Vista Service Pack 1 for x64-based Systems (KB936330)
Download size: 94.0 MB - 711.6 MB
Update type: Important
Windows Vista Service Pack 1 (SP1) is an update to Windows Vista that addresses key feedback from our customers. Windows Vista SP1 addresses specific reliability and performance issues, supports new types of hardware and adds support for several emerging standards. After you install this item, you will have to restart your computer.
ive tried to install this update but when desktop switches off it tries to install update in 3 stages but on 3rd stage it gets to about 95% and stops
It then goes back to normal settings
Any help on this would be so helpfull as iam going round and round in circles
Kind regards
fran
error 0xc004D401
Kind regards
fran
