Desktop Stand fixings for Panasonic Plasmas
Discussion in 'Home Cinema Buying & Building' started by Rambles, Dec 28, 2004.
  1. Rambles
    Rambles
    Jul 14, 2004
    8,306
    UK
    +1,282
    I am planning on getting a Unicol PFS stand for my Panasonic TH37PW7 as it has a very narrow depth, which fits on my mantelpiece.. www.unicol.co.uk
    They have stated this...
    "We haven’t seen the TH 37 PW7 but every Panasonic 37”, 42” & 50” PW models we have ever seen use the same fixings. We can make a PFS desktop pedestal stand for these models, the base size is 58cm wide x 24.8cm deep (front to back). Can you confirm if the PW7 uses the same fixings as the other PW models?"
    Anyone know the answer?
  2. blackmanalishi
    blackmanalishi
    I should be able to tell you but not until I get home tomorrow afternoon when I can measure mine, which is currently on the wall!
    If you don't get an answer from someone else by then I'll be glad to send you the answer... :)
  3. PannyAdams
    PannyAdams
    Dec 5, 2004
    669
    Epsom
    +5
    The Unicol stands atually use the Wall mount screws and not the two prongs that the Panny official stands use these screws are positioned to fit most universal brackets.
    I don't know where you live, but Seven Oaks HiFi in Epsom has a PW7 on a Unicol stand in its window - maybe a few other branches have?
    I think the rare but still obtainable Panny ST07 stand is probably narrower (Leading Edge in Newcastle claim to stock it). Better still would be the ST05 (the same but without the 'feet' at the front), however you certainly wont find one of these new (they pre-date pw5 - there are a few shots of these in the get your plasmas out for the lads thread) but if someone has decided to wall mount a previously desk mount you could get one cheap!
    Hope this helps
    Panny
