Desktop randomly shuts down
WattsX99
I am occasionally hearing a very faint sort of buzzing noise but could that just be the pump working?. To be fair, I'm probably deliberately listening out for it as well so i'm noticing it a lot more because the system is basically 99% silent as it is, which is what i was aiming for.
77red96
Yeah, I'd say so, it's possibly a little bit of air that was trapped in the pump from earlier, it should clear after a few hours of running.
77red96
If it hasn't cleared after a few hours I suggest turning the pc onto it's front face so the rad is higher than the pump, you can tap the pipes with your fingers while running too to help clear it.
WattsX99
Thanks, I’ll keep that in mind.
Considering it’s been arse about face for well over a year, I suppose it’ll need a bit of time to start working properly.
WattsX99
Just wanted to pop back with an update. Couldn't get the buzzing noise to go on my old system no matter what i tried (and I did try tapping the pipes as well) so in the end I did some research and bought this ..
Installed it earlier, and it's currently sitting at 22 degrees for the CPU. Even lower than my old one :)
And the silence ..
It's so quiet, I had to check it was actually on at one point !. It's ridiculous !
Samsung S95B Update, B&W Panorama 3 & Q Acoustics Reviews, HDR PQ EOTF/Gamma Calibration Discussion
