Desktop PSU Question
Discussion in 'Computer Components' started by shay0, Jan 2, 2007.
  1. shay0
    shay0
    Jan 9, 2005
    5,004
    God's Own County
    +489
    Right, I've fallen so far behind with PC hardware over the years, I find myself asking a noob type question :blush:
    My brother-in-laws PC seems to have blown the PSU. It's a cheapo 300W 24-pin ATX job and I've had a look at CCL (cos they're close) and the smallest 24-pin they have is a 550W. Would this be OK to replace the existing 300W duff one, or would it need another 300W replacement?
  2. peskywinnets
    peskywinnets
    May 8, 2005
    1,157
    48
    +59
    While I'd be tempted to seek a less powerful PSU (purely to save some ££££s), the 550W will be fine as the PC will only draw the power it needs...you could fit a 2000W PSU in there (if they made 'em)....& it'd still be fine
  3. Stuzo
    Stuzo
    Feb 12, 2005
    130
    Dunstable
    +15
  4. shay0
    shay0
    Jan 9, 2005
    5,004
    God's Own County
    +489
    That'll do nicely guys and thanks for the swift replies. As the 550W is only £12.84 anyway and all he only uses it for is music, surfing and a few football management games, I'll get that for him :smashin:
  5. zeus123
    zeus123
    The adapter is a good idea.
    You dont actually have to get a 24pin psu for a 24pin motherboard. Many people just use a 20 pin psu but at least with an adapter yuo cant plug it in wrong!
    Make sure you get a decent psu, it makes all the difference in the long run. The cheapest around is an FSP 300w. Its usually about £30 and will be a solid power supply which will last the test of time.
    In fact ccl do a hiper 350w PSU. This will be just as good as the fsp one I mentioned. The nest one up from ccl id go for would be the 330w Tagan but thats £40.
    Honestly... spend the extra £8 and get the Hiper PSU its so much better!!
  6. Stuzo
    Stuzo
    Feb 12, 2005
    130
    Dunstable
    +15
    I'd ecco that statement, spend £15 on a PSU and there is a good chance it won't last more than a year. Spend £30-40 on a 300-400w PSU.
  7. shay0
    shay0
    Jan 9, 2005
    5,004
    God's Own County
    +489
  8. Stuzo
    Stuzo
    Feb 12, 2005
    130
    Dunstable
    +15
  9. Jowl
    Jowl
    Nov 2, 2005
    613
    28
    +27
    Another vote for a quality power supply.
    Spend the little extra - worth it in the long run.
  10. shay0
    shay0
    Jan 9, 2005
    5,004
    God's Own County
    +489
    Cheers guys, I'll get it ordered tonight :thumbsup:
  11. tfboy
    tfboy
    Nov 17, 2005
    1,401
    Reading
    +454
    As others have said, it really doesn't pay to skimp on PSU. Would you run your HD tv with the cheapest DVD player that only gives you composite ?
