Question Designing a speaker set up around a living room
Discussion in 'Home Cinema Buying & Building' started by Basquelle, Jul 8, 2015.
  1. Basquelle
    Basquelle
    May 14, 2015
    173
    Bayonne, Pays Basque, France
    +15
    Yes, I know, it's all the wrong way round! But this is what I have to do, the room is primarily a living room, it is part of the B+B guest space at times, so I need to work around it.
    First and foremost, how much space should I have behind speakers for them to work well, and how much should I not have them backed into a corner? Which speakers will be the most forgiving of being backed up to a wall, or near a wall, or into a corner? You will be getting the idea by now that I'm not free to stand the speakers very far from the walls!
    The AV unit is a Marantz SR6009, the speakers are yet to be chosen, the focus is musicality. The room is acoustically neutral, about 5m wide x 4m deep x 2m high. I'm thinking a 4.1 or 5.1 set up, I really don't have space for any more channels, and I'm thinking of up to £1500 budget for the speaker array.
    I know purists will tell me to stick with stereo kit for music, but I do love the extra depth that surround sound gives stereo music, which is why I'm using an AV unit rather than a stereo amp. Given this, does the advice to use identical speakers on all channels hold, or should emphasis be placed on the fronts?
  2. Ghostrider
    Ghostrider
    Jan 3, 2006
    884
    43
    Warrington
    +127
    To get the best flexibility in terms of placement why not consider some speakers like the Kef T Series, Monitor Audio Shadow or Artcoustic's range that are designed to be wall mounted?
    However to answer some of your questions directly - most speakers don't like to be backed upto walls or in corners as it tends to effect the bass response - especially if they are a rear ported design.
    For their Bronze range Monitor Audio recommends a minimum of 10 inches from the back wall and around 3 ft from the side wall.
  3. Basquelle
    Basquelle
    May 14, 2015
    173
    +15
    I've looked at many reviews of the Kef T series, and I see a little question mark creeping in. For flat panels, they're good, it seems, but as replacements for conventional speakers, they seem unpopular. But what I can never find in a review is how a flat panel speaker compares to a conventional speaker that's too close to the wall!
  4. Ghostrider
    Ghostrider
    Jan 3, 2006
    884
    43
    Warrington
    +127
    Like everything speaker choice is a compromise - I'm sure that we'd all love some B&W Nautilus but most don't have the space or budget.
    I run the KEF T205 set which comes it at around your budget and for TV/Film they are outstanding as a sat/sub set. I don't really listen to music through them other than what is on TV or in the film I'm watching but I have no complaints whatsoever. How they would sound in direct comparison to a similarly priced set of floor standing speakers though I don't know and never will as they wouldn't fit in my room.
    Convention wisdom says that a full size loudspeaker setup will sound better if the setup is optimal - I don't think you'll ever find anyone to review a set of speakers who will purposefully place them in a corner and too close to the walls - what would be the point of that.
    It has often been said that speakers are a personal preference - for instance what sounds great to some may be lacking in bass to others. Try and audition a few different sets including on-wall and floor standing units and let your ears be the judge.
  5. Basquelle
    Basquelle
    May 14, 2015
    173
    +15
    I think you're right: I will have to go listen. I've been avoiding it, the nearest showroom is 2 1/2 hours away and is in Spain. My Spanish is limited to hello, goodbye and can I have a glass of red wine with that tapas please. So it's going to be fun!
    The line up, if I can arrange it, will be Monitor Audio Shadow 50, Kef T 3 series, Monitor Audio Radius R90HT1. Can anyone suggest other likely contenders? Budget is around £1500 for a 5.1 set up, with musicality the priority.
