Derek Cross, how do you connect...
Discussion in 'PC Gaming & Rigs' started by mikeq, Jun 13, 2003.
  1. mikeq
    mikeq
    Hi Derek,
    Tried to connect to your game last night after receiving your invite, usual story couldn't connect.
    How do you connect to your ADSL i.e through a router etc If so what make?
    You don't have on any IP blocking which may block my IP (range).
    Maybe we could do a test with you trying to connect to me, to see if it works that way.
    Just seems really strange that yours is the only connection I can't get into:confused:
  2. derekrcross
    derekrcross
    Feb 20, 2001
    442
    19
    alright mike
    you are not the only one who can not connect to me spunky dunc cant either i use cable broardband with a belkin router dont have a clue what its set on only it works can hold 8 on xbox live with 3 computers going at the same time if anyone has some ideas please help :D
  3. Duncan Craig
    Duncan Craig
    Jun 1, 2003
    258
    The Grim North
    +17
    Well if you ever fancy a game Max4orce let me know, cos we'll never get a clan match....hahahah ;-)
    SpunkyDunc
  4. mikeq
    mikeq
    Hi Duncan,
    I've had a few clan matches, usually the other team hosts or it has been okay when captaineyecatch hosts. It's just Dereks connection thats a problem for me:(
    I've got you in my friends list but never seen you on-line at the same time as me.
    Mike
  5. -Spike-
    -Spike-
    May 17, 2001
    1,608
    E.Sussex
    +293
    Guys,
    I've read quite a few posts on other forums about compatability issues with certain routers/modems on Xbox Live.
    This might be the problem here?
    As another example there are two guys on my friends list who use the same exchange and whenever they are on the same team it causes all sorts of problems, no voice, disconnection etc
    Although I think Del uses cable so the above probably is irrelevant it goes to show that there are issues out there.
    I'm trying to find the thread (without much luck) to see what/if there was a resolution.
    I'll let you know.
