DER TD6213 CRT help needed
Discussion in 'General TV Discussions Forum' started by Atiq, Dec 23, 2006.
  1. Atiq
    Atiq
    Dec 23, 2006
    28
    Hello Every one! My first post so please don't laugh. Below is purely for sentimental reasons.
    I inherited this ex-rental set some 20+ years ago. It had given me a wonderful service. Since last week it started playing up. First of all the picture would go dim for a few seconds and then brightened up as normal. Following day it happened more frequently as I switch it on but eventually settled down after a few minutes. This morning it came on for a while and then picture disappeared completely, sound is still there though for all the channels but no picture.
    I know it might have to be thrown away if the tube is gone but in the absence of a Circuit diagram, I do not have a clue. If it is worth repairing, I would like to a have a go. Any ideas to what could be wrong guys! Any help would be highly appreciated. Thanks
  2. JayCee
    JayCee
    Jan 20, 2004
    23,630
    Lanarkshire
    +2,550
    Dry joints on the crt heaters pins on the crt base...pins 5&6 (marked with "h") if I remember correctly... also trace the wiring from here to the main pcb and solder this end as well.
  3. Atiq
    Atiq
    Dec 23, 2006
    28
    Thanks JAYCEE! This would be at the back end of the CRT right! God it has been a long time since I opened one of these things.
  4. JayCee
    JayCee
    Jan 20, 2004
    23,630
    Lanarkshire
    +2,550
    Yes that's the crt base.
  5. Atiq
    Atiq
    Dec 23, 2006
    28
    JAYCEE! Many thanks m8. Sorted! Amazing what a good advice with a bit of soldering can do. The hardest bit was to get rid of all the dust on the main board. CRT pins had a lot of carbon. Very fine sand paper came in handy there. All working fine now.
    Thanks again.
  6. JayCee
    JayCee
    Jan 20, 2004
    23,630
    Lanarkshire
    +2,550
    Glad you got it sorted, I used to service them in the field many moons ago and they were far better made than most modern sets...I recognised the symptoms...this was a very common fault.
    Have a merry Christmas :thumbsup:
  7. Atiq
    Atiq
    Dec 23, 2006
    28
    Jaycee!
    You are spot on about the picture quality m8 and that was one more reason why I was reluctant to bin it. I would say that despite its age, the image is equal to, if not better, than some of the other models I have purchased in the recent past. Thanks again.
