Der Gamecube..........
Discussion in 'General Video Gaming Chat' started by Parmenion, Dec 11, 2003.
  1. Parmenion
    Parmenion
    Feb 6, 2002
    1,258
    Out there
    +50
    I need to hook up my gamecube to an AV amp via S video. Could anyone tell me if there is a particular S video lead thats better than any other.............or if there is a particular supplier to recommend.
    Any info would be greatly received
    regards
    Parmenion
  2. simon1
    simon1
    Jul 7, 2001
    918
    28
    Teesside
    +58
    If it's a UK console, then there is no option for S-vid.
  3. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,391
    +850
    I don't know if you know or not, but the best the gamecube can output is dpl 2.
    Sorry.
  4. Geezer
    Geezer
    Aug 5, 2002
    2,833
    68
    +25
    I think he was talking about s-video for video switching not to do with audio :smashin:
  5. Parmenion
    Parmenion
    Feb 6, 2002
    1,258
    Out there
    +50
    yes I was talking about routing the picture via S vid to my tv. Are you saying this isn't possible?
    I was led to believe that after market s video leads do exist.
    regards
    Parmenion
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    the leads sre N64 leads (cheap ones are anyway), proper job would be a JS RGB>S-vid converter but a bit more expensive than a GC lead!
    What disply are you connecting to?PLASMA, CRT, LCD PJ???
    What amp, does it do YUV switching?
  7. Parmenion
    Parmenion
    Feb 6, 2002
    1,258
    Out there
    +50
    My amp is a bog standard Yamaha. It does not have component inputs or video up converting.
    what it does have is left and right phono sockets and a S video socket mounted on the front which enables me to plug in an X Box and then later a Playstation 2. What I want to do now is plug in the gamecube via s video. Is this possible
    regards
    Parmenion
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    should also have S-vid sockets on rear, best bet is RGB Scart to TV and plug LR phonos in to amp, any input will do and you will get better PQ than with S-video switched by the amp!
    What display anyway?
  9. Parmenion
    Parmenion
    Feb 6, 2002
    1,258
    Out there
    +50
    The display is a 36inch TV. For many reasons, mostly involving not being able to have a games console plugged in all the time, I need to use the front S video socket. This works perfectly with the X Box and the playstation.
    Do I understand that the gamecube cannot be connected via s video
    regards
    Parmenion
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    UK GC will not output S-video, unless modded or a converter on the RGB outpu.
  11. tommy
    tommy
    Whereas the US- and JAP-versions do output SVideo like a charm :cool:
