Depth of PW7 incl Desk Mount?
Discussion in 'Home Cinema Buying & Building' started by Artie Fufkin, Jun 30, 2005.
  1. Artie Fufkin
    Artie Fufkin
    Aug 11, 2004
    1,600
    Aberdeenshire
    +182
    I'm now very close to buying a pwd7, but I would like to know from anyone who bought from AV sales, the depth of the unit including the desk mount which they offer, and does the stand protrude further back than the back of the panel? [I would assume it does for balance, but best to check]
    Also, is the "duck's feet" stand which you get, or the sleeker straight one?
    Thanks.
  2. Artie Fufkin
    Artie Fufkin
    Aug 11, 2004
    1,600
    Aberdeenshire
    +182
    ...or the one from progressive, I don't mind. Info on either would be good.
  3. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    30cm from back of stand to front of 'ducks foot'!
  4. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    and yes it does protude further back from screen by about 11cm
  5. Artie Fufkin
    Artie Fufkin
    Aug 11, 2004
    1,600
    Aberdeenshire
    +182
    Thank you mep. Very helpful, [I was hoping it would be a little less, but I suppose it *is* a heavy bit of kit]
