Depends on what you want from your upgrade( or from HK receivers)
Discussion in 'AV Receivers & Amplifiers' started by Halcion, Oct 17, 2001.
  1. Halcion
    Halcion
    Oct 11, 2001
    78
    9
    Ulrich,
    it depends on what you're after with the upgrade.
    If you want better sound quality I don't think the difference will be that huge (between your current Sony and the mid-level HKs).
    If you want new features (DPL II, etc) then you'll have to look at the new models (from HK top range and Onkyo/Denon).
    If you want more connectivity, well that can be arranged with the flagship models.
    If you just want to spend money, well - that's easily solved :)
    Cheers,
    Halcyon
