D
Deleted member 927641
Hi. I'm new here and no hifi expert, and have searched the site but cant find an answer to my question regarding a Denton 80 upgrade. If I missed something, apologies.
I have Denton 80s which I love. I just wish it had 'better' high frequency resolution - I really like the sound, just after more HF detail without brightness if possible. Can anyone suggest a significantly better speaker with a similar sound signature, which I would describe as warm, rich, smooth?
I asked the question of local dealer, and while they recommended the Lintons, they also indicated they be too much for my 4.5 x 5.5 x 2m (low ceiling) room that I listen across. There was a quick discussion about plugs, which I know little about effectiveness.
An overseas dealer suggested ATC SCM7. I think these (and 11 or 19's) could (definitely) qualify as significantly better, but from what I've read, not sound similar.
I've even considered finding a speaker expert about whether potentially swapping out the tweeter was a good option, as everything else about the speaker works. From what ive read I understand, changing tweeters is not completely straight forward (impedance, sensitivity, crossover, size etc) , but potentially possible whether a good idea or not.
Speakers I will audition so far are ProAc DB1, and Spendor 3/1. I've been told that D2R bass will be likely too much for my room.
Any thoughts or suggestions most appreciated. Thanks in advance.
